1vj choke partnumber.
Duc_Rider_NL
What Bike or Bikes Do You Own?: Ducati 998s
Xtz750
Xt600z 1VJ
Previously Owned Bikes: To many.
Post by Duc_Rider_NL »
Hi guys,
I’d like to convert my choke directly on to the carb. The cable one is broken on the top, plastic thread and a new cable is around 55€.
Looking for partnumbers here, I’ve searched but it’s not completely clear to me. The one installed currently is the one with a oring.
Can someone be clear of which part I need to order?
Cheers, Nick
Scumfrog
59x
43F
Re: 1vj choke partnumber.
Post by Scumfrog »
I've been considering this conversion for a while.
It'll be the choke from the TT600, Kedo have them. I haven't tried it, so can't say for sure that it fits.
Don't see why not.
Duc_Rider_NL
Xtz750
Xt600z 1VJ
Ok.
I’m not 100% sure the kedo fits. I prefer to wait for someone who did the transformation. Thanks.
Scumfrog
59x
43F
Post by Scumfrog »
Actually, that part is no longer available anyway.
But I'm told that the 2kf part does fit if the tip is cut down to 4mm.
They're more expensive than the original choke unfortunately.
But yeah, hopefully someone can confirm that.
Duc_Rider_NL
Xtz750
Xt600z 1VJ
This is the one that’s currently installed.
Duc_Rider_NL
Xtz750
Xt600z 1VJ
I ordered the kedo part.
Choke, complete (OEM), OEM Reference# 2KF-14371-01
Let see if it fits & works.
Cheers.
Scumfrog
59x
43F
Post by Scumfrog »
IVJ non original (kedo) choke on the left, 59X on the right.
59X choke fits in the 1VJ carb, the piston is a perfect fit.
59X choke up against the 1VJ carb.
The 2kf item looks the same as a 59X but with the pin of the 1VJ.
Choke, complete (OEM), OEM Reference# 2KF-14371-01 https://www.kedo.com/choke-complete-oem ... 71-01.html
Duc_Rider_NL
Xtz750
Xt600z 1VJ
Thx mate, as said I bite the bullit, let’s see.
carel_m
What Bike or Bikes Do You Own?: Yamaha XT600z 1VJ
Honda XRV650 Africa Twin RD03
Honda CT70 - Dax
Post by carel_m »
Hi, I was working with the same issue, a broken plastic piece of the choke plunger at the handlebars and a worn cable. I've sourced a 2KF carb from Marktplaats for 15,- and took out the choke which is placed directly on the carbs. This is the one with the needle on it and without the rubber o-ring so not exactly the same. If you remove the neelde it should fit on the 1VJ carbs. This setup has mixed reviews as I've read here and there. Mainly because of the lack of a good seal due to the absent o-ring. Will try it for now. Other option would be restoring the choke cable setup but I'm not very confident this will succeed. Cheers, Carel
carel_m
Honda CT70 - Dax
Post by carel_m »
Check this thread about the samen issue.
viewtopic.php?p=28731#p28731
