Fuel leak
Mark17
What Bike or Bikes Do You Own?: Yamaha XT 600 Tenere 1VJ
Fuel leak
Post by Mark17 »
Hello
It is a long time since I last posted ,I have been using the tenere a lot over the summer after bringing it out of hibernation all has been good until last weekend when I got home from a ride out I went in the house for a coffee and when I put the bike away there was a puddle of petrol under the bike it appear to be running out from the bottom of the carb,question is will it just be a stuck float or do I need to look at other stuff as well.
It does not appear to leak when it is running.
Here is a pic of the bike with a new friend.
Thanks mark
Re: Fuel leak
Yep. Stuck float valve if it was fine before. Bang a new gasket/seal in too when you give it a clean.
Before you strip it, drain it first and blow some cleaner /air through it to see if it sorts itself out. Might be a really quick fix. If she still leaks, strip away.
Mark17
Re: Fuel leak
Post by Mark17 »
donnybach wrote: Thu Nov 10, 2022 8:39 pm Yep. Stuck float valve if it was fine before. Bang a new gasket/seal in too when you give it a clean.
Thanks for the advice I will try the quick fix first.
Mark
Peen
Re: Fuel leak
Post by Peen »
Ive had a sticky float a couple of times, usually a few taps on the side of the float bowl with a screwdriver handle at the side of the road sorts it out, hasnt happened since.
Mark17
Re: Fuel leak
Post by Mark17 »
It was a stuck float,but I have another problem when I took the carb off one of the intake boots has come away from the metal,so I have ordered two new ones.
Looks like I will have to take the other bike on Sunday.
Mark
