Missing washer rear wheel
Everything else on your bike.
kissedin
What Bike or Bikes Do You Own?: XTZ 660, f800s, husqvarna mod 28
Post by kissedin »
Bike is an xtz 660 from 1997.
Just realized im missing the washer that is used for rear wheel alignment om right hand Side (behind THE nut with a cotter pin through it).
Number 31 on parts diagram (90201-171T3 alt 90201-177k7). Can anyOne please help me and grab a caliper and get me THE dimensions?
Need the bike tomorrow.
Cheers!
Re: Missing washer rear wheel
Well most jap rear axles are either 17mm or 20mm, so get one of each & you should be OK.
kissedin
Post by kissedin »
I was thinking in terms of thickness and outer diameter. The partnumbers differ from left and right washer so I guess it is kinda important that the dimensions are somewhat near spec.
kissedin
Post by kissedin »
I ended Up with standard washer while i am waiting for a correct One to arrive.
Now the trip is over. I survived 😁
