Finally my order from Powersports Plus (boatnet sister) arrived.
Mirrors, mastercylinder,all the bushes and seals for the forks,fuel tap,tail light lense,fork boot clamps and alot of other little bits and pieces.
Regards eric
Bush Slide 51121-48B31 $11.13 each (wide bush, smaller dia) , Bush Guide 51152-48B31 $9.60 each (bigger dia) , Oil Seal 51153-08D00 $12.08 each , Dust Seal 51173-15D00 $12.17 each( not identical to Tenere, but better according to Tenere Mike). Remember these are Suzuki part numbers and are available in Aust but are 2 times the price.
Got a worn out standard XT600 50T complete shocky, spring etc for $40 as I need the top section to go on the brand new 50T shock I bought as you can't get the original 34L one's anymore, the only problem is the big adjusting nut is seized. The only way I could get the spring off was cut the shaft. Put the bush end in the vice after heaps of WD40 applied and put some stilsons on the nut but now the threaded section turns with the nut. Does anyone have these parts to sell or advice on getting this apart?
Eric, if I catch you putting your manky bike parts on my nice new stone kitchen counter tops, I'll rip your head off and shit down your neck.
Quote.... Eric's Missus!!
Try soaking in WD40 or Penetrene for a few days. Or make your own from old mechanics recipe of 50/50 ATF and acetone. (Don't get busted pinching her nail polish remover (acetone))>
55W1985 wrote:Eric
I got the set from TT.de site.They where cheaper than the ones offered on ebay.
Quality is good.BUT NOT AS THE ORIGINALS!Thats the reason I left the 34L shematics on my tank.
I got the biger size of MONO CROSS decals.They have also the black front for the cowling,etc.
They also take paypal. http://www.tt600r.de/tt-kiosk/xt.htm
What was wrong with the quality and how the hell do you order from them
Bloody hard to remember where everyone`s at in there builds, i spotted a real nice Stoßdämpfer the other day i was going to let you know about, thought you had already done your Stoßdämpfer so didn't bother passing the link.
Had you seen this gem? im guessing you have?
Its loads of money, but there again Eric you've got loads of money.
