New plastic's are available from http://www.boatnetparts.com eg left side cover US$65.43, right US$58.33 as well as all fenders and just about anything else you need!
2KF
bopster
- What Bike or Bikes Do You Own?: XT600 2kf - XT600 1vj x2 - SR500 2j4 - XT/TT/SR500 profab project - Ducati 900ss
- Previously Owned Bikes: Lots
Re: 2KF
Sounds good to me Eric, is that the right address does't come up when I try it.
Cheers bopster
Cheers bopster
Kickstarts, remember them
Re: 2KF
Try this http://www.boats.net/parts click on OEM Yamaha then motorcycle and you will work the rest out.
bopster
Re: 2KF
Thanks Eric did suss it out, good to know bits are still available, will have to make a list
and see what I can get
cheers bopster
cheers bopster
Ffoxy
- What Bike or Bikes Do You Own?: Viewing am XT600 as a re-build Project.
- Previously Owned Bikes: Triumph T25SS
Honda XL185
Suzuki Bandit 600
Suzuki SV1000S - Location: Shropshire, UK
Re: 2KF
I cant be the only one to have this so what do you experienced restorers do? The screw isn't stuck in there broken off, it just has no thread... and is a little oval in shape. Drill slightly oversize & re-tap?
I'm going for the clocks from the gent in Greece by the way... sod the MPH I'll put up eith metric!
Re: 2KF
You may struggle getting an MOT Kieth unless your mates with a tester? as for the screw on the master cylinder your not alone its common to see as they made them with a Philips screw & many a butcher rounded them off over the years, i replaced the whole thing on mine & got it from ebay USA for around $50.00 (master cylinder/lever) at the end of the day your front brake is critical when some donut pulls out in front of you.Ffoxy wrote:I'm going for the clocks from the gent in Greece by the way... sod the MPH I'll put up eith metric!
- Founding Member
Re: 2KF
The solution for the stripped thread is to use "recoil" thread repair.
Read about it here.
http://www.afsrecoil.net/en/Overview/How_it_works.html
Anyone of us here doing resto work should get a 5mm,6mm and 8mm set. You can buy Chinese knockoffs on ebay.
You should be doing the head/barrel threads as a matter of course as well as this is a known weak point and easy to strip.
Or, go down to your local bike shop and have him do it, shouldn't cost more than a tenner to get one hole done.
Read about it here.
bopster
Re: 2KF
Never had any problems with getting an MOT in the UK with Kmh clocks 3 of my bikes have them
and never even got an advisory.
I agree with everybody else recoil is the way to go, saved many a restoration.
philb
- What Bike or Bikes Do You Own?: Yamaha XT600E, Honda CBR900RRT, Kawasaki KH400, H1E 500, RD350LC, VF750F, Triumph T140E Bonneville & XT1200z Super Tenere.
- Previously Owned Bikes: Suzuki AP50, GSX750EFE. Honda XL100, CG125, CB400/4, CBX550, CB900. Kawasaki KH250,KH400, H1E 500, GPz750Turbo, ZXR750H2, Z1000ST, Z1R. Yamaha RD250LC, RD350LC, RD400, XT600E, XJ650 & FJ1200.
Re: 2KF
Four stainless Exhaust studs in post Keith.
Phil
Phil
