Spark problem
Missinglink
- What Bike or Bikes Do You Own?: Tenere 55W .... T7 and too many others
Re: Spark problem
Doesn't make sense, so with a separate feed to the coil and CDI the voltage dips below the threshold and you get no spark ?
alands
- What Bike or Bikes Do You Own?: Yamaha xtz750
- Previously Owned Bikes: Honda xr400
Re: Spark problem
Sorry I miss-led you
I have only tried it with the coil and not the cdi
Will try it tomorrow
Re: Spark problem
Whenever i’m testing coils and spark the general rule of thumb i follow is that if everything around the CDI tests as good then it’s probably the CDI that is bad. Can you get your hands on a known good CDI and test with that? You said you got a cheap one…alands wrote: Sun Mar 24, 2024 4:08 pm Sorry I miss-led you
alands
Re: Spark problem
Just tried the cdi with a separate 12v supply.
Same result
Good sparks until I screw the plugs in
Has anyone got a spare cdi???
Same result
alands
Re: Spark problem
I’ve sent my cdi over too a company in Holland to repair.
They will have do a diagnostic on it and repair it needed
