So I'm into it just on $400, as can be seen it's in really nice condition and the cam tunnel is spot on. The base head has been blasted and the valves cut and seated, new genuine Yamaha valve stem seals fitted.
No bolts, screws, valve lifter or valve adjustment access covers included.
$300and will ship Australia wide at your expense
OR
will swap for a 3TB head in similar condition
I've put it up on Gumtree at $400, if you want to deal through there I'll only charge $350 offered here
