Carb Intake Manifold
Phill.R
What Bike or Bikes Do You Own?: Yamaha xt600z tenere,bmwr80rt combo,yAMAHA fjr1300,Kwaka Gpz600,Honda CB500
Post by Phill.R »
Daft question but are the carb intake manifold/rubbers model specific for each Tenere,ie,the IVJ manifold will only fit that model.Doing a rebuild and finding it hard getting cetain parts.Any info or advice really appreciated.
cheers
Phill.R
Re: Carb Intake Manifold
All the same mate, TT600 XT600 all the same (physical shape) just make sure you buy the one with a "Tap Off" one of them has an outlet, this is for running your vacuum fuel pump.
Phill.R
Post by Phill.R »
Thanks for the info,found a pair on mssp and they are £82 each for genuine ones.
Left one here on ebay (NOS) 45 quid.
https://www.ebay.co.uk/i/112801369795?rt=nc
jibber wrote: Sat Mar 17, 2018 12:39 pm Make sure you dont get restricted ones
restricted
https://www.ebay.de/itm/original-Yamaha ... SwldRaCtZJ
not
https://www.ebay.co.uk/itm/Carb-to-Head ... Sw7XZXgOfi
Good point John, forgot about them. :bag:
Phill.R
Post by Phill.R »
Thanks for the link,got the intakes ordered this morning so hopefully the old bike should fire up next week sometime. :thanks:
cheers
Phill.R
dirtwanabe
What Bike or Bikes Do You Own?: 1986 XT600 Tnere (1VJ) with a 3TB motor fitted
1997 BMW R1100RT
Previously Owned Bikes: 1980 R100RT
1973 XL175
Post by dirtwanabe »
I have a set of these cheap knock-offs on my bike and they work fine.
https://www.ebay.com.au/itm/Intake-Carb ... 90v3raaguw
Regards, Dave
Phill.R
Post by Phill.R »
Hi Dave,
Thanks for the offer but I managed to get a new set here and had them fitted.
cheers
Phill.R
Doubleyoupee
What Bike or Bikes Do You Own?: XT600Z
Previously Owned Bikes: Many
Post by Doubleyoupee »
Mezo wrote: Sat Mar 17, 2018 10:37 am All the same mate, TT600 XT600 all the same (physical shape) just make sure you buy the one with a "Tap Off" one of them has an outlet, this is for running your vacuum fuel pump.
Can any confirm that they are all the same, physical shape for all XT600's?
Because here, on this forum, apparently someone from Kedo, claimed that the 3AJ ones have different angles?
viewtopic.php?t=2471#p28194
