Hi Guys,
Little bit of an update, sorry for absence but long illness has hampered me somewhat.
Rebuilt the clutch with the bits that came with bike, replaced the knackered side casing and the shot water pump.
New battery.
Stuck in a bit of oil and ran it up.
Sorted dodgy side stand switch.
Bike now selects gears....
Carb out, cleaned and refit....bike now ticks over.....
Removed completely shot silencer and replaced with second hand unit, but fitted new exhaust seal.......bike does not now sound like a goose farting in the wind.
Next to sort is leaking fuel tap...seal kit ordered.
Rear suspension bottom linkage has more slack than a slappers chuff so will need sorting.
Struggling to source a rear rim that isn't rotten.....any ideas?
More to do but ever closer to a runner.
Plan is to get it through a MOT then see what i've got. Pretty sure the suspension wants a complete overhaul but until i've given it a run and seen what the engine and gearbox have in store i'm hanging back.
Adrian
Everything can be fixed with the correct application of the right sized hammer.
