Not at all pretty but then it doesn't need to be.
The plastics are all comprehensively knackered, the leak on the tank caused by some individual having a go with an overlong panel screw
Inner fairing panel missing, wiring is interesting
I have no idea why the top yoke nut has been welded?
The exhaust is beyond help. I will need a replacement so suggestions please
That is filler in the wheel rim and under it is a lovely crack........so that will be a new rim then
First impressions:
The engine runs but its a smoker....a least 40 a day
The clutct doesn't disengage the gearbox, the guy I got it from provided a complete spare clutch assembly but a look see should reveal all
All plastics need major work or replacement
Rear wheel rim kaput
The battery is a gonna
The carb is all over the place
Lots of little bits and pieces missing
Not sure the coolant system is up to much
The rear disk is warped and the rear brake will need a rebuild
i suspect this is the thin end of the wedge so expect some interesting pics as the strip down starts
Watch this space and wish we me luck, I'm going in.
Adrian
