Longer rear shock on a 34L?
xpag6259
What Bike or Bikes Do You Own?: Triumph Speed Triple 1995
Yamaha SR500 1978
Yamaha RT3 1973
Yamaha RT3 1973
Yamaha XT600 Tenere 1983
Yamaha TT600 1984
Previously Owned Bikes: Ducati 860GT
Suzuki GSX 250
Yamaha XJ900
Kawasaki GPZ
Yamaha CT3
Post by xpag6259 »
I have read on other forums about guys fitting TT600 rear shocks to XTs. They are 400mm compared with the 34L at 388mm. That 12mm at the mount should equate to a lift of around 30mm at the rear axle. Is that too much of a change? Will it twitch up the front end? This bike will be used for long distance touring with plenty of luggage.
any advice will be appreciated.
paul
so many projects, so little time
brage
What Bike or Bikes Do You Own?: XT 600 2 kf 1989 - tenerised..
Re: Longer rear shock on a 34L?
Post by brage »
Hi Paul.
I think you will do okay with a approx 30mm lift at the axle, I know -Kedo- a european aftermarket supplier spesialising the XT model, supply the Wilber rear shock with an optional - permanent extension giving up to 40mm tail lift. Advertising it will be better performance during cornering and such, my only concern is the chain run at the swing arm . But you can lift the chain using bigger sprocket at both front and rear f.ex. 1 more tooth in front and 3 more at the rear should equal the gear ratio.
Go for it , it also looks better :riding:
Best regards Brage
xpag6259
Yamaha SR500 1978
Yamaha RT3 1973
Yamaha RT3 1973
Yamaha TT600 1984
Suzuki GSX 250
Yamaha XJ900
Kawasaki GPZ
Yamaha CT3
Post by xpag6259 »
Thanks brage,
I have the shock, and its larger at the top than a standard shock, and I'll need to come up with a solution to get it to fit between the snorkels between the carbs and air box. You're right, it will look great!
regards
paul
55W1985
What Bike or Bikes Do You Own?: XR 650L 1994,XT 600Z 55W 1985
Previously Owned Bikes: CX 500 1981,R-80G/S PD 1987
Post by 55W1985 »
Hi
I am in the process now to rebuild this White Power shock.If you look carefully the lower end has an hex bolt for extending it out.I have no problems on the air box zone.I will extend the hose another 10 cm to locate the cannister on the rear part of frame(like TT600)
XR650L(1994) 55W (1985)
