Motor oil, air filter & oil filter: Type and webshop?
Troxx
What Bike or Bikes Do You Own?: Yamaha XT 600E - 4PT (1998-mod).
Previously Owned Bikes: Yamaha XT600Z - 34L (Tenere) 1983-mod.
Suzuki DR600 (1986-mod.)
Post by Troxx »
Recommended motor oil seems to be SAE 20W40SE, can't find this oil in the 4-5 shops I've looked in. Quality marking "SE" is old, I'm not sure what kind of oil to use.
Oil filter should be replaced too, but I'm not sure where or what to look for, often the images are general, and not spesific to model in webshops.
I've seen a magnet thingy for mounting with oil filter, is this somehing to use, what diameter?
My air filter foam is damaged and old, I think its best to get i all new.. It's a square(ish) sylinder.. where to find a replacement?
So.. what do you use, and where do you do your bargains :-)
Yaey...had my first ride yesterday, feels nice to be back on two wheels. :nordie:
EDIT (Is this correct?):
Air Filter: http://www.ebay.co.uk/itm/Air-Filter-YA ... 5636918fa5
Oil Filter: http://www.ebay.co.uk/itm/HiFlo-Oil-Fil ... 51973f4577
Recommended Oil type remains I think. (Temperature range +20 to -10 Celsius where I live.)
Re: Motor oil, air filter & oil filter: Type and webshop?
Kedo would be your best bet on webshop, although Dave Lambeth sells filters for the 3AJ as well (i got mine from him) here.
Oil filters off ebay, lots to choose from.
I think the "magnet thingy" you mention is a magnetic sump plug.
It replaces your standard sump plug with 1 with a magnet in it smile:
It holds metal particles & fillings in a place where they can't do any damage, until your next oil change, when you can clean them off.
Troxx
Post by Troxx »
Great :-) Thanks..
Found (@ KEDO) air filter & oil filter ... and this oil:
51545 4l 20W50 4 Stroke Mineral Motorcycle Oil (API SL, JASO MA2) --> replaces item 50658
This is a thicker oil than the "40" .. and I saw no other oil when xt 600 was selected in "motorcycle type" ...
What do you use?
Which oil viscosity depends on the air temp. where you use it & how long & hard you ride.
In a fairly cool climate like Norway, 10W40 would be the way to go unless you ride at full throttle ALL day :nordie: , in which case use 20W50 but let the engine get HOT before you thrash it.
Oils that start with "10" give better lubrication on start up (when most damage occurs) & gets to opperating temp. quicker than "20".
As your bike has an oil cooler without an oilstat (thermostat) as standard, the oil might take a while to warm up, but hopefully keep the oil from getting too hot.
I use cheap mineral 10W40 because my engine burns a lot of oil, when I get time & money to sort the engine I'll use 10W40 semi synthetic.
Troxx
Post by Troxx »
Is mineral oil 10w40 for cars ok? Kedo recommends (?) 20w50.. for motorcycles (xt 600).
What is best at 10 degrees Celsius: 20W50 that needs a warm up time made for MC? or cheap 10w40 for cars?
What I don't understand is the difference between oil for cars and MC ... say both should use 10W40.
EDIT:
The good stuff:
http://en.wikipedia.org/wiki/Motor_oil
The short version:
SF < SG < SH < SJ < SL < SM < SN (where S is for gasoline and C is for diesel, FGHJLMN are revisions)
Japanese MC's should use JASO T904-MA and MA2.. wet clutch needs special oil, not oil made for cars.
SJ, SL, SM and SN revisjon has demands to reduced use of phosphor and sink, which might be bad on older engines.
If you change from mineral to synthetic oil: synthetic oil could release deposits from mineral oil, so change oil and filter again after 200-500km.
:tenere: my kind of bike :-) (Yes i've tried the other styles)
Just works. Never runs out of fuel. No road is bad road. You don't need a road. The sound and comfort. Fun.
Jimmie
What Bike or Bikes Do You Own?: '85 Yamaha XT600Z
'93 Suzuki GSX600F
Post by Jimmie »
Er der ikke en Biltema i Ålesund? De har billig og udmærket olie til motorcykler, med de rigtige specifikationer (JASO-MA2).
I've not bought "motorcycle oil" for over 20 years, I always thought it was a way for the industrie to get more cash out of you.
I've done a few hundred thousand miles (60000miles/100,000kms on my Ten) using car oil & never had a clutch problem.
Love to know if anyone has had problems caused by car oil.
Always used it myself, and in cars (petrol ones) i always used deisel oil, my mate runs a garage in the UK & told me he's been putting it in customers cars for 30yrs.
Troxx
Post by Troxx »
Jimmie wrote:Er der ikke en Biltema i Ålesund? De har billig og udmærket olie til motorcykler, med de rigtige specifikationer (JASO-MA2).
There is, and their oil is probably ok. I've checked oil level, and its fine, but I have to change anyway. Ordered oil form KEDO, cheaper and more probably closer to Yamaha Spec. It made no difference in price, since there is a flat rate for shipping to Norway. My cart:
1 x 33046 Air Filter Set (inner & outer)
1 x 40535 Oil Drain Plug, Magnetic, M14x1.5/SW19
1 x 91002 Oil Filter for misc. YAMAHA motorcycles
1 x 50007 Taillight Lens, Square, E-marked (OEM)
5 x 27143 Rubber Damper Side Cover (Oval), approx.
1 x 51545 4l 20W50 4 Stroke Mineral Motorcycle Oil
1 x 27493 Spring for Side Stand, Large, Inner
1 x 27492 Spring for Side Stand, Large, Outer
1 x 94026 Cu-Washer 14x20x1.5mm
4 x 40042 Indicator, 1 Piece, Stem approx. 50mm
Edit : @Jimmie: Your language is danish but avatar says swedish?
