No turn signal mounts? No problem ;)
Bedheadjulian
What Bike or Bikes Do You Own?: an '87 Xt600z (1VJ), a '91 xt600E and a '13 xv950.
Previously Owned Bikes: BMW Funduro, Honda vt600
Post by Bedheadjulian »
All the local suppliers I know of (in Europe) are sold out of front turn signal mounts for the 80's XT600s (the ones that mount on the top fork clamp bolts) so I decided to make my own...I thought I'd share some pics and ideas for any of you that might be in a similar bind ;)
I was originally looking for some "Z" brackets or some flatstock that I could bend into shape as a basis for making the brackets when I stumbled on some heavy duty gate hinges in the hardware store and, lo and behold, they were almost the perfect shape and size for this little project. Made by a company called Starx (product #43.103.27) 60cm gate hinge. I sized them up and at six Euros each I figured it was a pretty low risk investment if they didn't work out.
Turns out they were perfect. I made a quick template and cut and shaped them with my grinder, and drilled out the holes for the clamp bolts and turn signals. A little black spray paint and Voila!
