Hi, anyone have a airbox door for sale? For a 1VJ 1987 Tenere. I purchased the bike but when I took the seat of I can see air filter with no cover.
Otherwise a part number and I'll try and find one. Thanks
Hi,
The airbox lid is part number 1vj1441200. If you have a 1vj model.
It costs €10.46 from csml parts and theres also a rubber seal for it. There may be cheaper online shops than this.
You should check if the original airbox intakes at the front underside have been blocked off or not as this is a common mod with the 1vj model, if so you need to leave it with the lid off or cut a hole in a new lid.
It may be possible to fit the lid from the latter 3aj model air box that has a intake snorkel in it but I dont know this.
Hope this helps.
Which petrol tank do you have fitted, ot looks like an aftermarket one.
