Xt600e 4pt clutch casing damage
simplesimon1
What Bike or Bikes Do You Own?: xt600z 1vj
Previously Owned Bikes: xt600 34l
Post by simplesimon1 »
Not sure if anyone can help me with this but here goes.
My clutch casing was slightly damaged inside when the nut holding the primary drive gear on came loose and forced itself against the casing.
I now have some damage where the oil seal is located.
I still have a depth of 7.5mm for a new oil seal to locate in but there is now a small lip of aluminium to push the oil seal over to fit it in its place.
Does anyone know if this should be there or was caused by the nut pushing on this part of the casing ?.
I could clean this aluminium edge off catefully, or try leaving it, or look for a used casing.
Any help on this would be great.
See in pictures.
Thanks.
Missinglink
What Bike or Bikes Do You Own?: Tenere 55W .... T7 and too many others
Re: Xt600e 4pt clutch casing damage
Post by Missinglink »
I would say with some careful prep that would go again. as long as the seal bites the casing sides and holds it square then job done.
