Xt600 wont start
Mestercool
What Bike or Bikes Do You Own?: Xt600 1991 3tb
HD super glide t-sport 2001 1450
Previously Owned Bikes: Suzuki intruder 125
Husqvarna sm610
Xt600 wont start
Post by Mestercool »
Hi.
My xt600 3tb starts on the first kick with choke on. if i turn of the choke the engine shuts down and then its impossible to get the engine to start again until the next day or in a few hours. When i try kick it the carb will float over
The carb has recently been cleened and everything changed inside. Float is working fine.
Is there someone who has had the same problem?
Missinglink
What Bike or Bikes Do You Own?: Tenere 55W .... T7 and too many others
Re: Xt600 wont start
Post by Missinglink »
Are your inlet rubbers in good condition ?
They are bad for splitting with age and allowing the mixture to lean out.
Mestercool
Husqvarna sm610
Hi.
I just put new ones in and changed the spark plug and air filter aswell
Get some cold start in the carb when it doesn’t start, if it fires you're in the right place.
Scumfrog
59x
43F
Post by Scumfrog »
Pilot jet issue? Was it changed for a different size?
