XTZ660 1993 No startup but backfires
untertaber
- What Bike or Bikes Do You Own?: Yamaha Ténére XTZ 660 1993, KTM Duke 390 2017, Honda Deauville 650 2002 (for sale)
- Previously Owned Bikes: Yamaha YBR 125, Honda varadero 125, KTM EXC 125 SM
Hello, ive been working on my tenere. I now have spark and fuel it seem.. but the bike still doesn't start, beside the occasional backfire. Could it be that the ignition timing is out of spec?? Is this a hard job to do? Thanks!
dzl
- What Bike or Bikes Do You Own?: 2001 TT600R, ex army XT600, 34L Tenere, 2001 FZ1, FJR1300
Re: XTZ660 1993 No startup but backfires
So you have a consistant spark when cranking? First pull the air filter out and spray aerostart in airbox. Does it start? If yes then likely have carb issue and/ or intake manifold air leak. If still no start then check valve clearances and then cam timing. Remove cam chain tensioner. Is the tensioner piston fully extended when you remove it? If so, cam chain may be stretched and may have jumped a tooth but unlikely.
untertaber
Hi, I will do. Valve clearance are in spec, doubt the cam chain is the issues.. bike ran fine for a while.
