i have two engines, one is a 34K the other il 34L
I found them partially disassembled, so i cannot say where this device is coming from
in one there was mounted the standard cap, as per exploded view i share
in the other one there was mounted this kind of device. It looks a sort of pump which was taking the motion from the camshaft I assume. I would say a small oil pump, even if there attached there's a small segment of blind pipe most probably not original
anybody knows how it was working and the function of this?
