FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper
TTXTZ3YF
What Bike or Bikes Do You Own?: XTZ6604MY3
CB500
speed triple 1050
SV 650
Post by TTXTZ3YF »
Hello
I have a 1996 XTZ660 4MY3. Dismantled front forks to fit new oil seals and found I have no "FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper" fitted !! Can anyone say if this is important? Forks basically worked ok without. Is it perhaps just to make it easier to locate bolt into damper rod on assembly or is it more than that? They appear to cost £40 each, if I can get them. Any advice would be gratefully received,
cheers
Tony
Re: FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper
Post by charliext1vj »
Tryingvto work out what it is on this phone...isn't it the dust shield? As long as fork seal has the locking ring should be ok...but will wear quicker....will try and look on lap top later!
TTXTZ3YF
CB500
speed triple 1050
SV 650
Post by TTXTZ3YF »
Thanks for the reply. It's not the dust seal. It's inside the fork at the bottom of the damper rod - no 10 / 27 in this diagram.
cheers
Tony
Yes looked at - looks critical part and needed - but I guess you know that. As you say £40 for it compared with a set of second hand forks for circa £100. Had a quick look round nothing jumping out cheaper - good luck
Charlie
TTXTZ3YF
CB500
speed triple 1050
SV 650
Post by TTXTZ3YF »
Thanks for the reply Charlie, much appreciated.
XT3DS
What Bike or Bikes Do You Own?: XT600Z 3DS
Post by XT3DS »
The oil lock piece acts as a hydraulic bump stop for the last millimeters of travel of the fork. You could assemble your forks without it if you don't plan on ever bottoming out your suspension, but such situations are not always planned. It's better to find another one and install it.
TTXTZ3YF
CB500
speed triple 1050
SV 650
Post by TTXTZ3YF »
Thanks xt3ds. That makes sense, I'll see if I can get them ...
novavoyager
What Bike or Bikes Do You Own?: Kawasaki Z900
Post by novavoyager »
Thanks for the information.
