CARBY EXPERTS
I have the above arrangement on my 1VJ can anyone see an issue with this?
I have an issue that may or may not be related, that being after about 5klm of riding the old girl seems to be fuel starved and stops, hit the starter after about 30 seconds and all seems well and ok. Is it possibly a float issue? or something else....
1VJ carb on 2001 motor
Re: 1VJ carb on 2001 motor
Firstly Nick, and i always say this as it caught me out & many others.
Is the float needle valve filter clean?
Mezo. (Banana Bender)
- Three to collect
- What Bike or Bikes Do You Own?: 1986 1VJ Tenere, 1997 Fireblade 900RR, 1988 3AJ Tenere
- Previously Owned Bikes: 1989 ZXR750, GPZ900R, GPZ750, RZ350, IT490K, IT175H, Italjet 350T, TY175C, KX250
Yes, it should be as l had the carb rebuild by a proper motorcycle mechanic, but l will take the bowl off and check all is ok inside there
And in our line of work what's them magic words? never assume.Spike wrote: Sat Nov 06, 2021 12:46 am Yes, it should be as l had the carb rebuild by a proper motorcycle mechanic, but l will take the bowl off and check all is ok inside there
Download the CARB TUTORIAL Nick, page 16 onwards is where you need to be checking.
- Three to collect
Is it possible that there is a vacuum forming in the petrol tank?
To complete the trinity of fuel restrictions, the stuff between fuel tank (Breather in cap) and carb should be taken into account. Clogged taps, fuel lines, or fuel suction pump if there is one on that bike.
