display cutout
collmat
What Bike or Bikes Do You Own?: 2009 xt660 tenere. 2004 drz 400
display cutout
Post by collmat »
having trouble . believe it is electrical. bike starts and runs but after say 15 miles engine management light comes on and display goes off. drop gear and rev it usually comes back on. any ideas. can anyone help. cheers.
Patrick
What Bike or Bikes Do You Own?: 1988 Yamaha 3aj Tenere.
2009 KTM 570 EXC
Re: display cutout
Post by Patrick »
Its not quite the same but I had a Toyota van years ago that had the exact same issue and the problem was the oil pressure.
If it doesn't involve scotch, bikes or progressive metal then you're doing something wrong.
'09 570 EXC.
'88 600 Tenere project.
R.A.G Endurance Racing.
Re: display cutout
Assuming this was for the 2009 660 in your profile I moved the thread to the relevant forum
Re: display cutout
Also, iirc, check wiring around the headstock
Re: display cutout
Further investigations on 660.com suggest maybe loose connections,water in system, low battery........perhaps
collmat
Re: display cutout
Post by collmat »
Thanks for suggestions. Have already replaced rectifier/regulator, had charging system checked and renewed battery. will try suggestions and see what I can find
