Carburettor removal
Pensioner
What Bike or Bikes Do You Own?: Yamaha XTZ 700 Tenere
Previously Owned Bikes: Matchless G2 250 (passed test)
A Norton atlas, BSA lightening (nice bikes)
Triumph Bonneville x2 (1 stolen 1 burnt out)
Kawasaki H1 mach 3 500 (feckin scary)
Franz Egli black shadow (fast & loud)
Ex-works Thruxton Bonneville (even faster)
BMW F650, R1100 GS (never missed a beat)
Yamaha xt 500 (could not start the bastard)
BMW 1200 GS ( big comfortable mile muncher)
Yamaha XT 600e ( i could start this one)
Carburettor removal
Post by Pensioner »
Hello just got a 2000 xt 600e the float sticks there is not a lot of room to work between the cylinder and airbox, what is the best way to remove the carburettor for a clean and a refurb ?
Re: Carburettor removal
Post by charliext1vj »
It just takes time - tank of, tank a load of pictures of the hoses and cable runs....remove carb to engine boots - check condition of these -- remove air box rubbers ...and so on
dzl
Post by dzl »
Hi......Loosen airbox/ carb runner clamps and slide all the way back. Take out top airbox mount bolts and slide airbox back as far as possible. Loosen and totally remove clamps on carb/ head intake runners. Removing these clamps totally allows the runners to flex just a little more to allow easier carb removal. Disconnect fuel hoses/ throttle cables etc. Keeping the airbox rearward as possible manipulate carb out from LHS of the bike. Be patient and may need to spray some WD40 etc on rubbers to help slide it out.
Once I can get the carb out of the way a bit I try to get to the intake flange bolts and unfasten them, then remove carb and flanges.
Pensioner
Post by Pensioner »
Ok i'll try that thanks, difficult to find neutral is this common on xt's?
Depends. Those wet clutches have some drag so hard to find neutral when not riding (sitting at a traffic light etc). No problem with engine off, or rolling along.
Pensioner
Post by Pensioner »
Thanks, will the oil i use make any difference?
For the dragging? No.
But if you use the wrong oil (hitech stuff for cars) the clutch will drag AND slip under load.
Just stick to the Yamaha spec
dzl
Post by dzl »
motorang wrote: Thu Jun 27, 2019 12:15 pm Once I can get the carb out of the way a bit I try to get to the intake flange bolts and unfasten them, then remove carb and flanges.
mmmm....Ive never had to remove the inlet manifolds for carb removal. That sounds like hard work?
Pensioner
Post by Pensioner »
motorang wrote: Fri Jun 28, 2019 5:10 am For the dragging? No.
Thanks Andy
I'm using 20/50 mineral
