Need 1Vj clutch cover
Hey everyone, I'm on the hunt for a 1VJ clutch cover to match a set of case halves. I'm trying to rebuild a 3AJ with 1VJ case halves but need the clutch cover for the starter motor mounts. Anybody holding onto the elusive unobtanium? I can pay for delivery to the States if it doesn't run in the thousands of dollars... damn shipping fees
Re: Need 1Vj clutch cover
The 1VJ uses a bracket to mount the starter motor, the covers did not have them cast in until the 3AJ
https://www.ebay.co.uk/itm/YAMAHA-XT600 ... SwZrJakVsg
Looks like that
Looks like that
That is good news indeed. Thanks for the sherlocking
dirtwanabe
- What Bike or Bikes Do You Own?: 1986 XT600 Tnere (1VJ) with a 3TB motor fitted
1997 BMW R1100RT - Previously Owned Bikes: 1980 R100RT
1973 XL175 - Location: Berry, NSW, Australia
The lugs on the rear end of the starter are a bit different as well, the 1VJ starter lines up with the bracket and the later starter has longer, offset lugs that line up with the bosses on the crank case. I found this out when I fitted my 1VJ starter to my new 3TB motor, I made some spacers to go between the lugs on the starter down to the crank case bosses but it needed to starter to be rotated slightly which caused the rods that hold the starter ends together foul on the oil return pipe. I just fitted the original bracket and all was good, it made it look a bit more original as well.
Dave
Dave
Regards, Dave
Can you post some photos of what you encountered?
dirtwanabe wrote: Mon Mar 26, 2018 4:10 am The lugs on the rear end of the starter are a bit different as well, the 1VJ starter lines up with the bracket and the later starter has longer, offset lugs that line up with the bosses on the crank case. I found this out when I fitted my 1VJ starter to my new 3TB motor, I made some spacers to go between the lugs on the starter down to the crank case bosses but it needed to starter to be rotated slightly which caused the rods that hold the starter ends together foul on the oil return pipe. I just fitted the original bracket and all was good, it made it look a bit more original as well.
Dave
dirtwanabe
Hi,
here is the 1VJ starter on the 3TB motor using the original mounting bracket from the old motor. You can see the unused boss with the arrow pointing to it. The other one is obscured by the motor. Also notice the angular displacement between the lugs on the starter and the boss, I originally made some spacers and longer bolts to mount the starter after rotating the starter so the lugs were parallel with the boss.
The spacers looked fine when the motor was on the bench but when I put the motor back in the frame I could not fit the oil return pipe because rods holding the starter together got in the way.
I hope this makes sense.
All the best, Dave
All the best, Dave
Regards, Dave
