I had loads of spares kicking around so I got them together and had them powder coated I've shrink wrapped them and put them in the loft for a future build, I had a set of wheels so got the rims and hubs coated then had them built up with extra thick spokes so got a set of wheels ready as spares, two swing arms had them done black for a change, set of forks done black as well, have two frames with number plates one a 34L and the standard 43F I will end up putting the two back on the road at some point,
The 43F I fancy doing a custum build with the small, it's in the planing stage at the moment as I'm not quite sure what direction to take it but that's next year, I've get two engines to choose from,
I want to keep everything black then the frame white the oil tank red, not sure if I want to use any panels as I want to keep the lines simple, the colours will tie everything together
