Hint and tips to buy a second hand 3AJ
Viloc
What Bike or Bikes Do You Own?: 2006 Suzuki VL intruder 800 "slightly" modified
1988 Ténéré 3AJ under maintenance
Previously Owned Bikes: 1998 Daelim VT 125
2007 BMW GS 650 Rotax engine
Post by Viloc »
Hi guys!!
I'm looking for a 3AJ, and I'd like to know what to see, or where to look when I find one of theese beauties. Specially oil leaks, where are more common, or where means a bad thing... Also any sound of the engine, or during start up, gears, etc... Like that, anything related with any problem that this bike can have, and that can be identified with a visual inspection, and driving for a while during a test.
Thanks in advance
Viloc
Si vis pacim, para bellum
Re: Hint and tips to buy a second hand 3AJ
There is nothing much to check, only what you would on any bike (wheel not buckled, brakes not leaking, fork seals not leaking, engine not smoking) basic checks.
The only main problem with any XT600 is worn fifth gear, just listen for whining noises in top gears, and make sure it doesn't jump out of gear.
Listen for knocking noise from bottom (same on any bike) you may hear a "tap tap tap" this is normal as the valve clearance may need a simple adjustment, same on any engine.
So your main thing is the gearbox, to watch.
Viloc
Post by Viloc »
Thanks Mezo!! I'll check for the gear, and other stuff like in other bikes, for leaks and so.
I've found a red&white one that cames from a couple of brothers that are suposed to be used to rebuild old motorbikes. Now the engine is open, and has sent some picks of it
I'll post them, and I'll very happy to read all your comments and opinions about it, or if a different picture would be interesting to check whatever. I've talk with him a couple of times, and looks like hi knows what are he doing, but...
Thanks in advence
Regards: Viloc
Post by xtrider »
I'd be leary of any fresh rebuild. While there are some good ones out there , most times if someone is selling the bike anyway they won't built it (or put the best parts in) like a person does if it your own. I walk away from anything freshly redone or consider it as needing a full redo and pay accordingly.
Viloc
Post by Viloc »
First of all: Thank you very much Mezo for all the bikes you have suggested me. Lastly I've founded a red&white one close enough to take a look to.
Thanks for your advice Xtrider. The guy selling the bike looks professional in this dutty, is used to restore bikes with his brother, and sell them later. I've been talking with him, and all answers look normal. For sure, it is not a guarantee of anything, but I'll see the bike and test it before buying. Hope everything goes ok.
Hopefully in early march I'll have enough time to visit these two guys, their workshop, etc... and probably get the bike to its new home in mid march, or maybe during eastern hollidays.
I've have lot of plans for the bike... One idea is lighten the bike as much as possible by removing certain parts, as passenger footpegs, rear rack, etc...and change other by carbon fibre parts as fairings, covers, mudguard, engine protection plate, etc... Also the combinated use of aluminium and carbon fibre for some part. Exhaust is other part to replace...I've found that most common one is the Arrow, but not able to find the weight of the Arrow one and the weight of the stock one. If any can help with that information.. :thanks: If I'm not wrong, the 3AJ, with all the fluids and full tank reach 185 kg, and I would like reach 160 kg only.... :hot: I know... is very optimistic. I'd like this lighter motorbike for trail trips, having a easily to handle Ténéré, but also I'll keep all the original parts to have the real bike at any moment. Also I am thinking about fit the kickstart, but still need lot of reading through this forum to know how to... :mornin:
Regards: Viloc
keny72
What Bike or Bikes Do You Own?: 1986 Honda VFR750Fx2, 1997 Honda Transalp 600, 1995 Honda SevenFifty, 2001 Kawa ZR7S, 1994 Kawa Zephyr 550, 1985 Yamaha FZ750
Previously Owned Bikes: 2004 Suzuki DL650, 1990 Yamaha FZR600, 1986 Yamaha IT200S, 2006 WR250 Husky, 2010 Yamaha XT1200Z, 1984 Suzuki RG250W, 2000 Honda VFR800FI, 1991 Honda VFR750F, 1987 Honda VFR750F, 1985 Honda CBX750F, 1986 Honda VFR750F, 1987 Transalp 600,, 1992 Honda CBR600F, 1997 Kawasaki KLE500, 2001 Suzuki Bandit600S, 1987 Kawasaki GPZ500S, 1982 Suzuki GS500 Katana, 1990 Yamaha FJ1200, 1982 Yamaha RD125LC, 1983 Yamaha DT125LC, 1990&1989 Yamaha XT600Z Tenere, 1981 IT465, 1985 KTM125GS x3, 1987 KTM125GS, 1989 KTM250GS, 1996 KTM400SC, 1994 Kawasaki KX125, 1992 Kawasaki KDX200, 1996 Suzuki RM250, 2006 KTM250SX, 1995, 1997 & 2002 CR125R, 1996 CR250R, 1981 Suzuki PE175, 1989 Suzuki TS250X, 2011 BMW R1200GS, 2005 KTM EXC250 Racing, 2009 Yamaha XT125X, 1995 XRV750, 1990 CBR1000F, 2000 Yamaha TRX850
Post by keny72 »
So is the gearbox worry mostly only the 1988 3AJ problem (as 1VJ), as the 1989/90 3AJ has a additional oil feed for the gearbox as different primary and secondary gear ratios to sort this gearbox problem. I have understand that the 1989 on 3AJ gearbox is same as the later 3TB XT600E´s and they are durable.
