Where's the spark gone ?
Anything Electrical
Jools
What Bike or Bikes Do You Own?: XTZ660 Tenere
GSF1200 Bandit
Previously Owned Bikes: Too many to list
Post by Jools »
I was given a non running '93 3YF which I finally got running recently, although it would only run on full choke ! After welding up a big hole in the exhaust, the bike would not start at all. Checking the plug, I noticed a very week spark so I replaced it with a new one. Now it won't spark at all even though the old plug still gives a weak spark. Coil and plug cap seems ok so why no spark ?
Re: Where's the spark gone ?
Did you weld the pipe while it was on the bike?
Zonda
What Bike or Bikes Do You Own?: 1991 XT600
1999 TRX 850
1969 CB450 (Honda)
1969 CL450 (Honda)
1970 CR450
Previously Owned Bikes: Wow, where do i start!!! well 1974 Honda XL 100 and then………arh my head hurts.
Post by Zonda »
Mezo wrote:Did you weld the pipe while it was on the bike?
...............with the battery connected?
You never get over the desire to do stupid things. You simply have
to overrule your stupid urges with an acquired sense of fear.
Possibly fried the TCI (Thyristor Controlled Ignition) similar thing to a CDI (Capacitor Discharge Ignition) on earlier Xt`s.
If it was working up until you did some welding that could be the cause? :dunno:
This guy has two for sale.
If you welded with everything connected the alternator will need checking as well.
Jools
GSF1200 Bandit
Post by Jools »
My welder has told me he is not a plonker and removed the exhaust system before welding
Make sure you are getting 12 volts to the coil, the red/white wire.
How did you check the coil?
Is the HT lead ok? They get hard & brittle over time.
Jools wrote:My welder has told me he is not a plonker and removed the exhaust system before welding
Easy enough to prove by looking at the nuts where it bolts to the head, caked in mud or rust means welded in situ.
Jools
GSF1200 Bandit
Post by Jools »
Having problems finding a replacement coil, would any 12volt motorcycle coil do ?
doghouse
What Bike or Bikes Do You Own?: xtz660 3YF
Xl650V
Previously Owned Bikes: Suzuki AP50, Yamaha FS1E, Kawasaki KE125, Honda CB125Twin, Yamaha DT175dx, Yamaha RD250LC, Yamaha XJ550, Honda VF500F2, Yamaha RD500LC, Honda CBR600, Yamaha FZ750, Suzuku GSX750ESD, Yamaha XJ900, Yamaha FJ100, Yamaha FJ1200, Honda CX 500 x 3, Kawasaki GT550, Honda NTV600, Aprilla Pegaso, Bmw 1100s, Yamaha XTZ660, and quite a few more than slip my memory
Post by doghouse »
I think I have a spare amongst all the bits in the workshop, I will check tomorrow.
If not, Halgeir has one from the bike he's breaking. And probably all the rest of the electrics if urs are cooked?
I'm on the surrey/sussex boarder if I can help?
Adrian
Everything can be fixed with the correct application of the right sized hammer.
