Thought it about time I put pen to paper, even though not a great deal has happened yet, this started out as more or less half a bike I bought the same time as a couple of other more complete ones, both 3AJ. Unfortunately I don't seem to have any before pictures (twat)
the frame and swingarm before being cleaned up
the frame and swingarm after being refinished (2 pack)
an empty engine,partly blanked off, nearly ready for glass bead
rear linkages after blasting
after plate waiting bushes/bearings
done
sorry Mez, no, Gloucester born and bred, was just trying to find a bunch of other pictures, but suspect they may be on the pc at work. other work to date involves rebuilding the crank, sticking the forks back together, refinishing the yokes, tarting up the inside of the shed and spending a fuck load on new parts.....piston, rings, gears, liner, oil pump, swing arm bearings, linkage bearings/bushes, engine bearings throughout, conrod, gudgeon pin, crank pin, big end blah de blah blah blah.
more to come
