Page 9 of 11
Re: Tenere 1VJ Rebuilding in the Netherlands
Posted: Wed Aug 14, 2013 7:05 pm
by Oldtimer
The picture of the fuelpump, carburetor and again the other one with the hoses with hopefully the right labels.
Is "??????????" also a "breather/vent pipe"?
Where do I leave/put/mount the 'breather/vent pipes' hoses?
Posted: Wed Aug 14, 2013 10:25 pm
Yes that one is also a breather pipe... just run them all down under the bike, I usually tie them together & pass them through a hole in the sump guard, I leave about 2 or 3 inches hanging down...
Posted: Mon Aug 19, 2013 9:04 pm
by Oldtimer
Started with the wires and exept for the headlight section (still waiting for it) it all fits, did a first test with the taillight, brakelight and the turn lights and they work.
Found a problem when starting the engine, is only (electrical) starts when I pull the clutch. Found out the Neutral switch isn't working, have to buy a new one. Also found out the regulator/rectifier has a shortcircuit and also has to be renewed.
Is there a way to check the regulator/rectifier?
... and there is a oil-sensor at the left bottom of the engine but i can't find any wire to connect to it, not even in the schematics?
Posted: Mon Aug 19, 2013 10:03 pm
Oil sensor? Don't you mean the neutral light switch?... Blue wire, that's probably why it'll only start with the clutch in
Posted: Tue Aug 20, 2013 7:52 pm
by Oldtimer
GeoffD wrote:Oil sensor? Don't you mean the neutral light switch?... Blue wire, that's probably why it'll only start with the clutch in
No, I did not mean the Neutral Light Switch
Posted: Tue Aug 20, 2013 11:10 pm
Oil sensor?
Well i've never seen one of them before?
Posted: Tue Aug 20, 2013 11:49 pm
by xtzrick
Mezo wrote:Oil sensor?
Looks like someone has lost the drain plug & fitted whatever they had with the right thread.
Why would you fit an oil sensor in a dry sump?
Perhaps they thought flashing lights on the dash looks cool
Posted: Wed Aug 21, 2013 7:52 am
xtzrick wrote:Why would you fit an oil sensor in a dry sump?
I was thinking the same thing, i have an oil tank with a temp sender fitted which makes more sense.
Posted: Thu Aug 22, 2013 9:46 am
Very strange.....
Posted: Thu Aug 22, 2013 11:11 am
by xtzrick
If there's no wire to fit to it I'm fairly sure it's just a quick fix for a lost plug, it's what I'd have done
Seen Dr650s use the sump plug hole to fit a temp sensor when they use after market clocks, but they are wet sump.
Looks like it's leaking anyway
I'd just fit a new plug & washer & forget about it.
Is that oil pipe leaking as well?
