XT600E 1991 Ex Aust Army Project
Re: XT600E 1991 Ex Aust Army Project
Danny, is he sure about 2.2 thou..... sounds a bit tight to me.... :rtfi:
I know we all like a nice tight fit..... but ummmm :bouncing-boobs:
GeoffD wrote:I know we all like a nice tight fit..... but ummmm :bouncing-boobs:
I like a tight fit, always checking to see if the Bournville Boulevard is open & ready for traffic. :shades:
Danjet600
Post by Danjet600 »
the barrel bored out and ready for that new piston :star:
1mm over size slywink:
Murray Walker
Danjet600
Post by Danjet600 »
got some motivation and removed the side cover to inspect the clutch, all nice and clean in here!
clutch is in good nick too
as i was having a look around i think i found my bottom end knock :sherlock:
as you can see the primary drive gear nut is loose and there is a lot of play :bigeek:
so i took off the nut and found alot of play in the key :yikes:
can't get the primary drive gear off without removing the clutch basket so i had to knock up a tool for holding the clutch still so i could undo the nut
pretty sure this was the cause of my bottom end knock, the sound was coming from the clutch side
close up of the key
and the key way
looks like there's some wear in the key way, the left side isn't straight :cry:
:sadnanna: not happy
Murray Walker
and.....?
Post by Fred333 »
Hi Danny,
I think it is no drama.
The key is the soft part in this relationship. The crank will be fine. Get a new key and everything will be fine.
The key just gives the position of the gear. If the nut is tightened properly it will take the load.
Just my opinion... maybe rubish...
Fred
Dirtybrit
What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
Post by Dirtybrit »
Fred333 wrote:Hi Danny,
Fred
Yes Dan I don't think it is a problem, if the new key is a bit loose, buy some oversize keystock and file it to suit.
Danjet600
Post by Danjet600 »
Dirtybrit wrote: Yes Dan I don't think it is a problem, if the new key is a bit loose, buy some oversize keystock and file it to suit.
that sounds like a plan, that should also take up the small amount of wear in the drive gear, bearing cover washer and balancer drive gear, now i'm in 2 minds about the engine build, do i go the whole hog and split the cases new big end ect or do i just do a top end build??? :scratch:
i measured the conrod to crankshaft side clearance 0.50 the book says between 0.25 and 0.75
now how do you measure the small end??????? book says 0.8 and free play limit 0.031 :book:
:ears:
Murray Walker
Danjet600 wrote:now i'm in 2 minds about the engine build, do i go the whole hog and split the cases new big end ect or do i just do a top end build???
Split it mate. :rtfi:
Mez.
Just Dan
Post by Just Dan »
Mez.
There is a bit of work in splitting the cases. In the end it might be better to split the cases. If only to have a look inside at the gears and it is the only time you can clean out the oil pan.
Bacon and eggs...A day's work for a chicken, a lifetime commitment for a pig.
Danjet600
Post by Danjet600 »
went down the road and bought 2 x 300mm lengths of keystock, got 7mm and 5/16" cost a whole $13 :biggrin:
a quick trial fit of the 7mm looks good :star:
Murray Walker
