I know we all like a nice tight fit..... but ummmm
XT600E 1991 Ex Aust Army Project
- Founding Member
- What Bike or Bikes Do You Own?: 7 x 3AJ Teneres
Honda Dax - Previously Owned Bikes: Triumph Tiger Cub, Garelli Tiger Cross, Triumph Trophy 650, Honda CB250 G5, Honda CB750 K7, Yamaha DT175MX, Honda CB250 Super Dream, Yamaha RD350LC YPVS, Honda XR250, Yamaha XT600, Suzuki PE175, Yamaha YZ125, Yamaha RD500 V4, Yamaha XT600 Tenere (3AJ), Kawasaki ZX10, BMW R100GS PD, Honda XR600, Honda Varadero, Honda Africa Twin, Honda Transalp, Triumph Thunderbird, Ducati 900 Superlight FE, Ducati 750 SS, Honda Fireblade, Kawasaki Versys 650, Suzuki GT750 Kettle, Super Tenere
Re: XT600E 1991 Ex Aust Army Project
Danny, is he sure about 2.2 thou..... sounds a bit tight to me....
I like a tight fit, always checking to see if the Bournville Boulevard is open & ready for traffic.GeoffD wrote:I know we all like a nice tight fit..... but ummmm
Danjet600
- Founding Member
- What Bike or Bikes Do You Own?: xt600e 1991 ex australian army
the barrel bored out and ready for that new piston
1mm over size
1mm over size
Murray Walker
Murray Walker
Danjet600
- Founding Member
got some motivation and removed the side cover to inspect the clutch, all nice and clean in here!
clutch is in good nick too
as i was having a look around i think i found my bottom end knock
as you can see the primary drive gear nut is loose and there is a lot of play
so i took off the nut and found alot of play in the key
can't get the primary drive gear off without removing the clutch basket so i had to knock up a tool for holding the clutch still so i could undo the nut
pretty sure this was the cause of my bottom end knock, the sound was coming from the clutch side
close up of the key
and the key way
looks like there's some wear in the key way, the left side isn't straight
not happy
close up of the key
and the key way
Murray Walker
Murray Walker
Fred333
- What Bike or Bikes Do You Own?: Yamaha TT 600 1984
- Previously Owned Bikes: Vespa Rally 200, Vespa SS 50 and alot more old (real) Vespas!!!
and.....? - Location: Hamburg , Germany
Hi Danny,
I think it is no drama.
The key is the soft part in this relationship. The crank will be fine. Get a new key and everything will be fine.
The key just gives the position of the gear. If the nut is tightened properly it will take the load.
Just my opinion... maybe rubish...
Fred
Fred
Yamaha TT 600 36A59X3SW - Mix
- Dirtybrit
- What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
- Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
Yes Dan I don't think it is a problem, if the new key is a bit loose, buy some oversize keystock and file it to suit.Fred333 wrote:Hi Danny,
Fred
Danjet600
- Founding Member
that sounds like a plan, that should also take up the small amount of wear in the drive gear, bearing cover washer and balancer drive gear, now i'm in 2 minds about the engine build, do i go the whole hog and split the cases new big end ect or do i just do a top end build???Dirtybrit wrote: Yes Dan I don't think it is a problem, if the new key is a bit loose, buy some oversize keystock and file it to suit.
i measured the conrod to crankshaft side clearance 0.50 the book says between 0.25 and 0.75
now how do you measure the small end??????? book says 0.8 and free play limit 0.031
Murray Walker
Murray Walker
Split it mate.Danjet600 wrote:now i'm in 2 minds about the engine build, do i go the whole hog and split the cases new big end ect or do i just do a top end build???
Mez.
There is a bit of work in splitting the cases. In the end it might be better to split the cases. If only to have a look inside at the gears and it is the only time you can clean out the oil pan.MEZO wrote:Split it mate.Danjet600 wrote:now i'm in 2 minds about the engine build, do i go the whole hog and split the cases new big end ect or do i just do a top end build???![]()
Mez.
Bacon and eggs...A day's work for a chicken, a lifetime commitment for a pig.
Danjet600
- Founding Member
went down the road and bought 2 x 300mm lengths of keystock, got 7mm and 5/16" cost a whole $13
a quick trial fit of the 7mm looks good
Murray Walker
Murray Walker
