Page 24 of 117
Re: Eric66 34L Resto
Posted: Sun Dec 04, 2011 2:00 am
by 55W1985
Eric
I got the set from TT.de site.They where cheaper than the ones offered on ebay.
Quality is good.BUT NOT AS THE ORIGINALS!Thats the reason I left the 34L shematics on my tank.
I got the biger size of MONO CROSS decals.They have also the black front for the cowling,etc.
They also take paypal.
http://www.tt600r.de/tt-kiosk/xt.htm
Posted: Sun Dec 04, 2011 4:12 am
by Eric66
Thanks Karl, I will order a set. Fixed the oil leak from the stator cover, it needed a slightly thicker o-ring on the 2 oil passages. Also the popping was coming from a small leak on the exhaust where the header pipe meets the muffler. Runs and idles sweet now.
Posted: Sun Dec 04, 2011 5:40 am
Out of interest how much is the COMPLETE sticker kit then?
Posted: Sun Dec 04, 2011 5:43 am
by Eric66
From the website about 53 euro if you need everything.
Posted: Sun Dec 04, 2011 6:47 pm
by 55W1985
Eric
30 for the big set(tank and side covers+front guard stripe)
Then 5 for the cowling(I did that myself)
4+4 each swing arm monocross
Total 43.-
The two black decals for the sidecovers........I would use paint,as original.
Posted: Thu Dec 08, 2011 8:26 pm
by Eric66
Spotted a good transmission on U.S Ebay, $50 for the lot. Arrived yesterday and is in mint condition just like the first set I bought.
Posted: Sat Dec 10, 2011 8:09 am
by Eric66
Got to work on de-spoking the rear wheels, put some WD40 on the spokes a few days ago and all but 2 on both rears came undone! Need the hub from the newer wheel as the bearings are loose in the original. These pictures show how much stronger the Tenere rims are over the normal XT, check out how thick the sides are on the Tenere rim, Tenere rim on right in both pictures.
Most likely I will re-zinc the spokes.
Would love to use the beefier 21x1.85 later model rim but I can't lace the hub onto the rim as it only has 32 spokes compared to 36 on the Tenere or XT.
Also does any one have a easy way of getting the piston out of the caliper? Tried compressed air, was told to put a grease nipple in the bleed hole and pump it with a grease gun but can't find a 7mm grease nipple.
Posted: Sat Dec 10, 2011 10:00 am
If that piston is shagged Eric you may as well tack a bolt & yank the bugger out with a bit of a twist action as well..
The re-zincing option is a good idea, Danny was well pissed off he just paid for a new set of of plain ol zinc spokes at $300.
Posted: Sat Dec 10, 2011 10:11 am
by Eric66
Ya can still buy OEM for $87US per wheel from boatnet!
Posted: Sat Dec 10, 2011 3:32 pm
by xtzrick
Best way to get the piston out is to reconnect it to the master cylinder & pump it out with brake fluid.
