Page 17 of 117
Re: Eric66 34L Resto
Posted: Mon Oct 31, 2011 10:26 am
Yeah some prick took fifty three virgins all in one go? :scratch:
Im on the same page as Billy, gimme two fire breathing whores any day. :rtfi:
[youtube]F53KqJS_TkU[/youtube]
"A wee fuckin winda"
Mezo. :biggrin:
Posted: Mon Oct 31, 2011 9:50 pm
by Eric66
Need some more advice regarding the crank. There is a small amount of movement ( up and down) of the crank in the left side case, the bearing is a C (high speed with 3 thou clearance). Now I know there should be no movement at all so I took the motor to 2 bike shops that specialize in Thumpers and both said basically it's the free play in the bearing and maybe the case where the bearing sits has gotten a little loose ( Yamaha cases are noted for this one said). Both said to live with it and it shouldn't hurt the motor?? Will some of the play take up when she warms up? I also asked my brother who is a Ducati trained mechanic and he many years ago replaced his crank for the same reason only to find when the new one went in it was loose too. Should I go with the fingers crossed method or is there something else I could do?
PS I checked as best I could with a test-dial indicator and there maybe 5 thou movement up, maybe less as it was hard to stop the motor moving when testing.
Posted: Mon Oct 31, 2011 11:16 pm
I seem to remember Just Dan mentioning this when he rebuilt his Eric? have a read through his build.
Posted: Wed Nov 02, 2011 8:11 am
by Eric66
Yes Dan had the loose bearing on the crank which they all seem to have, but mine seems to be loose in the side cases. Should I go with it or find new cases? Anyone?
Posted: Wed Nov 02, 2011 9:21 am
The crankcases have a "cast in" steel support ring for the bearings. :sherlock:
It is EXTREMELY unlikely that the is any movement in the case support, in fact you had to heat the cases to get the bearing to slide in!!
C3 bearings are the loosest standard bearings available and are used in mass produced automotive applications to hide minor (acceptable)
machining errors.
Chillax over this "problem" and move on to the next challenge.. :lol:
Posted: Wed Nov 02, 2011 9:38 am
by Eric66
Thanks, will continue on.
Posted: Thu Nov 03, 2011 9:03 am
by Eric66
Dropped my pipes and tank into the powder coaters for a bit of sand blasting.
Just got the under side and seam blasted as there was a bit of surface rust.
Gave the pipes a squirt of heat proof black stuff.
Also got the motor etched primed.
Then painted the next day.
And here's a couple of pic's for Mezo!
PS I rotated the pics in photo bucket but only some will copy the right way up?
Eric66 34L Resto
Posted: Thu Nov 03, 2011 9:35 am
Head & barrel look fantastic Eric, how did you sand them fins? by hand or with a die grinder?
Posted: Thu Nov 03, 2011 9:38 am
by Eric66
It's cheating using the die grinder!
Posted: Thu Nov 03, 2011 1:16 pm
by xtjoe
Very neat, wish i had a picture of the other clown that did the sandblasting in the plastic pool, now that was another story :guinness: Keep it up.
