Danjets Honda Transalp
Danjet600
Re: Danjets Honda Transalp
Post by Danjet600 »
ordered some of these for the alp :superman:
Murray Walker
Danjet600
Post by Danjet600 »
remember this
i took to the rear rim with a die grinder to clean up the corrosion
then had a go at filling the damaged area with an alumaloy rod, first attempt :bigeek:
nearly done, used a sand paper cone in the die grinder to remove the excess filler
only problem is when i had a go at the front rim the corrosion is so bad the rim is beyond repair so
i will have to get replacement rims :pissed:
it seems to corrode under the anodizing :scratch:
sort of in layers like an onion :tough:
Murray Walker
Danjet600 wrote:sort of in layers like an onion
Ah know Monsieur, i have ze same problim !!
Mezo. :biggrin:
Danjet600
Post by Danjet600 »
got stuck into the removing the spokes today, started with the front wheel managed to undo 1 spoke to get the length, the others i cut.......with wire cutters.......by hand :huh:
nearly done, the spokes are fuckin hard to cut :sadnanna:
so i prepared myself with some better tools when i did the rear
the grinder with cutting disk is the go slywink:
Murray Walker
I hope you made careful note of the spoke/rim orientation and the hub/rim offset? :sherlock:
If you dont take care, you can end in a world of hurt, just ask Just Dan? :censored:
Danjet600
Post by Danjet600 »
ActionManMelb wrote:I hope you made careful note of the spoke/rim orientation and the hub/rim offset? :sherlock:
well i took a shit load pics from all angles :dunno:
Murray Walker
Danjet600 wrote:well i took a shit load pics from all angles :dunno:
Last time Danny had a go with the neighbors kids pushbike. :lol:
[youtube]dxVQPbN21kQ[/youtube]
Danjet600
Post by Danjet600 »
made a start on the front headlight fairing
so i got the die grinder and started removing the previous "repair"
being plastic i have plastic welded some cracks together the larger areas need the carbon fibre kit slywink:
and i removed the screen
gave it a polish
Murray Walker
Danjet600
Post by Danjet600 »
OK i'm back, where have you been you might ask?
fooking crook i had a case of the great galloping bot rot, 8 days :bigeek:
any way on the mend now, my wheels and spokes finally arrived :star:
only problem the spokes are not right :headslap:
the bend is all wrong, so send back and get it sorted
Murray Walker
Didn't Dan (the other Dan) have the same issues?
What a pain. :sadnanna:
