Keihin carburetors
Re: Keihin carburetors
Or like has been mentioned in the power thread go fuel injection, that fits & works.
Jens Eskildsen
I have the double ninja carbs....Not that the factory carb didnt work, just wanted to fiddle with it.
It works just fine, I guess its slightly better than stock, but nothing outrageous
I had to go a tad up on idle and mainjets, and shiw the needles around 1mm up with small washers.
I had a slightly off idle stumple, which took me a while to sort out. I dont think the needels have a perfect shape, but I didnt want to buy the dynojet kit for the carbs either :)
Zonda
- What Bike or Bikes Do You Own?: 1991 XT600
1999 TRX 850
1969 CB450 (Honda)
1969 CL450 (Honda)
1970 CR450 - Previously Owned Bikes: Wow, where do i start!!! well 1974 Honda XL 100 and then………arh my head hurts.
You never get over the desire to do stupid things. You simply have
to overrule your stupid urges with an acquired sense of fear.
tall-mike
- What Bike or Bikes Do You Own?: 1989 yamaha xt 600 enduro
- Previously Owned Bikes: 650 yamaha
kawasaki 500 triple
suzuki 800
yamaha 80cc
yamaha 55cc
mini-bike 2.5 hp - Location: California
Well got the carbs in the mail. Keihin cr33's.Hope they are not to big, second guessing myself on the smaller cr31's.Purchased new intake manifolds and push-pull cables also.Stripped the bike down today ,ready for install tomorrow.In the middle of a hundred degree heat wave.So beer brakes were mandatory.Removed top bolt on rear shock for more working room.Had to do some running around (shopping) for air-cleaner boots, (2" diameter rubber coupling, purchased at plumbing department at "Home Depot".) A little shaving with a sharp razor and a Dremmel tool to fit nicely,and angle slightly away from the rear shock. As a filtration system This rubber boot will be covered by the inside foam of a pod filter, used on dirt bikes,already shaped to fit.The petcock on the xt600 is smaller in diameter than the gas line needed for the Keihin carbs (5/16 or 7mm).But by using the original gas line (very thin in outside diameter) as a shim,just covering the petcock nipple, the larger gas line fits perfectly.I'll be at it again tomorrow. Mike
I think you be right with 33`s if not take advantage of them & tune it further.
And you know worldwide forum rules (on any forum) no pictures it never happened.
tall-mike
kawasaki 500 triple
suzuki 800
yamaha 80cc
yamaha 55cc
ok Mezo I'll have the good woman dancing around me tomorrow taking pictures while I'm sweating bullets.....Mike
Xt600 stripped, ready for installing Keihin CR33 Carbs
Manifold is a 2" diameter rubber plumbing fixture cut in half, springs scavenged from a pod filter and I'll be using the interior foam sleeve of that pod filter. Thanks, Mike
tall-mike
kawasaki 500 triple
suzuki 800
yamaha 80cc
yamaha 55cc
Carbs were a tight fit,throttle cables installed and gas tank has just enough clearance for the throttle linkage. Should have it up and running tomorrow. Mike
tall-mike
kawasaki 500 triple
suzuki 800
yamaha 80cc
yamaha 55cc
Ok...It's alive, After hooking up the gas line and kicking it till the bowls filled up ,it fired up. It does idle to high at 3000 rpm ,but I'll dial that in tomorrow.
Two flips on the throttle and it pegs the tach, it never went over 7000 rpm on the stock carbs, now all I know is that it easily pegs 9000 rpm in just a flip of the throttle. Test ride tomorrow Mike
Can't wait.
- xtrider
