As I bought my Tenere as a pile of bits I was assuming that everything was original, but I am quickly coming to the conclusion that it was a hotchpotch of other models.
I was getting stuck in to rebuilding the caliper today and bedded the new seals and new piston. When I got round to the pads, it became quite obvious that I had ordered the wrong ones - I assume the correct ones are meant to have a circular hole for the retaining rod to go through aren't they? Anyone know which ones these are for so I can resell them with the correct description?
Now, I have managed to locate two of the retaining clips and placed them in the right place (one at the pit of the caliper and the other on the sliding arm or mount). What role does the one on the mounting arm play by the way?
but from the look of things, this third one isn't for the 34L/55W caliper is it? If so, anyone know where it goes?
From looking at the pdf for the parts manual it looks like there is another clip that hooks over a pad - would that be right? Or do the pads just hold in place by that one central pin? I can't see enough detail from the parts list exploded diagram.
Can anyone point me in direction of the right part number or flog me a spare they don't need?
Thanks in advance
EDIT: Sorry about the picture sizes, I thought I had got them all adjusted. Apologies
