MEZO wrote:Well im sure if Kieth got a piece of steel turned up with a slightly smaller ID than the axle bolt & with a small point on the end to locate it in the recess, then a good whack with a decent heavy hammer it would come out im sure.
A nice heavy lump hammer would do the trick.
Alrite XT magicians! Tried this method after a week of penetrating oil treatment & the nasty little barsteward wont budge a millimter!
So plan B is the threaded bolt through the pivot bolt & try winding the bugger out. Plan C involves cutting out the frame fillets that the bolt passes through....
...or even plan d...find some islamic militant types that are sure to have access to explosives and then blast it out??
hopefully you wont have to resort to that..
good luck..
What Bike or Bikes Do You Own?: Yamaha XT600E, Honda CBR900RRT, Kawasaki KH400, H1E 500, RD350LC, VF750F, Triumph T140E Bonneville & XT1200z Super Tenere.
Any farming or 'Heavy' engineering place near you mate?, they usually have big -off hydraulic or 'wind-down' presses. Maybe they could apply alittle pressure to bear on the offending item?
I got the local bods near me to straighten out my Predator exhaust clamps which were still fitted to the downpipes as you can't remove them (8mm thick stainless plate and the previous owner had still bent the F****ers so both sides of the clamps touched the cylinder head )
Well.... a mate had a go, he rebuilds old Brit bikes & even he was beat.... I'm gonna see what a local mechanic can do, see if he has experience & the kit to shift just 1 bolt... This is holding stuff up!!!
