I had thought to spray the whole thing silver or black,but in the end decided to go with the silver and black idea.
after having filed the fins back to metal.
I was wondering how to paint the 'YAMAHA' on the clutch cover silver, but its embossed into the plate and for love nor money couldn't get it to look decent. So i binned the idea and just painted it black. Still, i quite like the look of it as it is. I am just praying that once the bike is running again the paint doesn't come off
cause i don't fancy pulling the thing apart again just to spray the motor.I had some trouble getting the engine back in on my own. I had to use a small trolley jack and a heap of luck hoping the bike wouldnt fall over as the motor was going in. How i ended up doing it was, I bolted the two pieces of the frame loosely to the motor, then placed the whole lot onto a block of wood on the jack. Then manouvered the lot into place and jacked it up into place. quickly slotted in the swing arm bolt and two at the front and bob was my uncle! I dont recommend this to anyone, but at the time i had to do it on my own with not much in the way of help from the tools i have. If you have a extra pair of hands, be that your mates or your wifes, it will make life a lot easier and less stressful. I think it was sheer luck that the motor didnt fall off the jack and break something expensive. So not the brightest idea i have ever had
Anyway, the motor survived re-installation and here she is
And even had time to start adding some of the decals that Gustafsson sent from far far away
I am going to replace the screen at a later date, so in the mean time i have sprayed it white and added some art to it. looks way better than the manky original.
.......hmmmm...... now where the hell are my other photos??? forfucksakesman!!!
