Hi folks, hoping someone can help me out...
I've just removed the carby from my 98 XT600E. I think the rubber boots that join the carby to the intake manifold need replacing. I've done a search for the parts, and almost every search comes back with one of the boots having some sort of hose connector on one of them (see https://kedopartsaustralia.com/intake-m ... f-13586-01 as an example).
The boots that are currently on mine don't have any such connector piece so I'm a little confused on what needs to be replaced.
Any advice would be appreciated.
Thanks,
Rob
Rubber boots from carburettor to intake manifold
Scumfrog
- What Bike or Bikes Do You Own?: 1VJ
59x
43F - Previously Owned Bikes: quite a few off and on.
Re: Rubber boots from carburettor to intake manifold
From what I've seen, I think all aftermarket ones are like that, and there's a small cap that you can buy separately to close off the air hose connector.
dzl
- What Bike or Bikes Do You Own?: 2001 TT600R, ex army XT600, 34L Tenere, 2001 FZ1, FJR1300
Yes that is standard, used to check ...just a rubber cap needed.....easy/ cheap from your Yam dealer, see parts 4 and 5 here
http://www.firstclassmotorcycles.com.au ... ke#content
Make sure you don't get restricted ones.
