Hi
Now that I am finishing the resto I was wondering wich is the widest tire I could fit on the back?
Say 140/80/18 would fit? Karoo2 orT-63 desert?
Any advice
Gracias
34L/55W rear tire sizes
55W1985
- What Bike or Bikes Do You Own?: XR 650L 1994,XT 600Z 55W 1985
- Previously Owned Bikes: CX 500 1981,R-80G/S PD 1987
XR650L(1994) 55W (1985)
- Founding Member
Re: 34L/55W rear tire sizes
I am using Hidenau 140/80/18.
It is a tight fit on the 1VJ Tenere, about 4mm clearance each side.
55W1985
So info on XT.de is that early Teneres(34L,50T,55W) can use a maximum of a 130/18 on the back.That is due to the oil tank on the back.
Now actionman your 1VJ has a oil tank identical to our early models too?
Ive got Kenda K772 Carlsblad tires on two of my bikes, more suited to dirt riding though not road use.
These are 110/100 - 18 (i think)
Mez.
Mez.
55W1985
You see Mez there is no much left space there between tank and tire.......
Love that lubricated chain tho......
Yep about 10mm tank clearance, and about 15mm around the swigarm (by where the shock mounts).55W1985 wrote:You see Mez there is no much left space there between tank and tire.......
Chain does look a tad rusty, id be putting a new set on anyhow when i get round to its restoration (years away)
Them tires are off the pair i brought from the farmer, his mate owned them most of there lives & they was mainly used as desert race bikes.
Apparently one of these bikes (the one with the upgraded shock) has had lots of work done to its engine & its a bit of an animal to ride.
keny72
- Three to collect
- What Bike or Bikes Do You Own?: 1986 Honda VFR750Fx2, 1997 Honda Transalp 600, 1995 Honda SevenFifty, 2001 Kawa ZR7S, 1994 Kawa Zephyr 550, 1985 Yamaha FZ750
- Previously Owned Bikes: 2004 Suzuki DL650, 1990 Yamaha FZR600, 1986 Yamaha IT200S, 2006 WR250 Husky, 2010 Yamaha XT1200Z, 1984 Suzuki RG250W, 2000 Honda VFR800FI, 1991 Honda VFR750F, 1987 Honda VFR750F, 1985 Honda CBX750F, 1986 Honda VFR750F, 1987 Transalp 600,, 1992 Honda CBR600F, 1997 Kawasaki KLE500, 2001 Suzuki Bandit600S, 1987 Kawasaki GPZ500S, 1982 Suzuki GS500 Katana, 1990 Yamaha FJ1200, 1982 Yamaha RD125LC, 1983 Yamaha DT125LC, 1990&1989 Yamaha XT600Z Tenere, 1981 IT465, 1985 KTM125GS x3, 1987 KTM125GS, 1989 KTM250GS, 1996 KTM400SC, 1994 Kawasaki KX125, 1992 Kawasaki KDX200, 1996 Suzuki RM250, 2006 KTM250SX, 1995, 1997 & 2002 CR125R, 1996 CR250R, 1981 Suzuki PE175, 1989 Suzuki TS250X, 2011 BMW R1200GS, 2005 KTM EXC250 Racing, 2009 Yamaha XT125X, 1995 XRV750, 1990 CBR1000F, 2000 Yamaha TRX850
Waking up a old post here..........
Did find this: http://www.horizonsunlimited.com/hubb/y ... enere-5513
so its possible but not recommended......
and I that has started to think I might get a Karoo 3 for my 3AJ...
