Exhaust Studs
BS1948
What Bike or Bikes Do You Own?: Triumph Sprint RS 2003
Yamaha XT600E 2003
Suzuki DR125S 1983
Previously Owned Bikes: Loads
Exhaust Studs
Post by BS1948 »
:omg:
Right, I have removed the exhaust from my 2003 XT600E but at the cost of snapping off two of the studs. One is right where it goes into the head so, I assume needs drilling out. The other one, awkwardly placed behind the frame downtube, has all of the stem still in place but I cannot shift it! I have sprayed it with ACF50 and applied a bit of heat but it wont move. Any helpful tips??
Re: Exhaust Studs
That will need some time.
Respray it twice a day for a week.
Try to move it both directions every day.
Whats your workshop setup? Do you have a MIG/MAG/TIG welder? Do you have a friend with a welder?
Best bet is to weld a nut onto the stump then remove the one behind the downtube.
Then fabricate a drill guide (metal or at least hardwood), bolt it to a cleaned thread next to it (would be better to use 2 or three bolts)
then drill the other stump out, starting with a center drill and following with bigger diameters. Ideally use left handed drill bits, if they catch they will move the bolt outwards.
If you can get a clean 3,5 mm hole into the bolt you may try hammering a torx bit of size TX25 home and try turning the bolt with that bit. I recommend the best quality I can find, I have a German Hilti torx bit just for that.
Thats expert level stuff really. If you are not up to the job failure is almost certain, as the studs are steel and sit in a soft Aluminium alloy thread. Better chance would then be to remove the engine and let a machine shop have a go, without the downtube in the way.
Best of luck!
PS for later: Do not use original parts there as they will not hold up (they just rust away).
I always go for zinc plated studs if available (small engines may have them for carb or exhaust, they are standard M6 thread) or remove the head from a zinc plated M8x40 bolt and use that as a stud. And I use copper plated nuts.
It is a good idea to use ceramic paste for assembly.
BS1948
Yamaha XT600E 2003
Suzuki DR125S 1983
Re: Exhaust Studs
Post by BS1948 »
Thanks M
I don't have any welding facilities at all. My local bike workshop is going to have a look to see what they can do.
I will keep spraying anyway. I have drilled out broken bolts before but the left hand drill idea sounds good. I have some stainless studs to replace the mild steel OEM rust bugs. We'll see how we get on. :nannawave:
Re: Exhaust Studs
motorang wrote: Tue Nov 24, 2020 4:27 pmBest bet is to weld a nut onto the stump then remove the one behind the downtube.
Yep what Andy said, weld a nut or just weld on to the stud & grab the weld with molegrips then wiggle it out, and then drill/tap them all out to 8mm & replace with stainless studs.
Bowler
What Bike or Bikes Do You Own?: -Yamaha XT600Z Ténéré '90
-Yamaha MT-09 Tracer '15
Previously Owned Bikes: -Honda XL500S
-Suzuki GSX1100E(T)
Re: Exhaust Studs
Post by Bowler »
BS1948 wrote: Tue Nov 24, 2020 7:32 pm Thanks M
Be careful with stainless steel, as this can give galvanic corrosion. I'd stick with galvanised studs as motorang said! In my XT600Z I've replaced one with an mate stud, as the thread was buggered.
Re: Exhaust Studs
You'll probably end up having to take the head off I reckon... one of the bikes I bought had something similar, the previous owner had tried to drill out 2 broken studs, but he completely messed it up by drilling down the side of the old studs... it's a really hard thing to do with the engine in the frame.
I got a machine shop to fix it up for me... I always use stainless studs to replace the old ones, but make sure you smother the threads in copaslip before you fit them.
Bowler
-Suzuki GSX1100E(T)
Re: Exhaust Studs
Post by Bowler »
I took the engine out of the frame to do the drilling, otherwise it was not possible.
BS1948
Yamaha XT600E 2003
Suzuki DR125S 1983
Re: Exhaust Studs
Post by BS1948 »
Thanks for the advice lads. 8mm studs sound like a really good idea. 6mm is far too small!! I take it the holes in the clamp will take it?
B
Bowler
-Suzuki GSX1100E(T)
Re: Exhaust Studs
Post by Bowler »
Could be, can't remember if I've also bored the headers to suit.
Re: Exhaust Studs
BS1948 wrote: Wed Nov 25, 2020 1:53 pm8mm studs sound like a really good idea. 6mm is far too small!!
David Lambeth does it on most his rebuilds as a standard mod when rebuilding an engine, pretty sure he uses SS studs.
