hi, anybody got a photo of where the coil should sit on the frame. Bought a basket case without one soI bought an aftermarket one from Brooks barn and I'm not sure it's correct.
Any info much appreciated
tenere 1VJ correct coil location
charliext1vj
- Halfway there
- What Bike or Bikes Do You Own?: 2 XT600s -1VJ, BSA Bantam Trail, CRF1000, BSA B25 if I can find all the bits!
- Previously Owned Bikes: too many to list - XT600s, cr500, KTM 990 Adv, VFR800, RDs, DTs
Re: tenere 1VJ correct coil location
http://members.chello.nl/h.hoorn6/yamah ... re_1vj.htm
similar to how I have mine - but I wrap it past the main frame to reduce the heat
thanks, give us a clue, where's the coil mount photo?
- Halfway there
Follow the ignition cable, there it is, front downtube left hand side
Brilliant thanks Andy
The coil I've bought has a two bolt mount that doesn't seem to match any mounting on the frame.
Is the coil rubber mounted as my frame has a tang for a rubber in that location very similar to the battery box relay mount tangs.
charliext1vj
- Halfway there
have you found your answer - send a picture of it - not sure which one you have so far doesn't sound like early xt600.
- Halfway there
It sits on a tang:
Check the exploded view
https://www.cmsnl.com/yamaha-xt600z-198 ... Mc5k4rgrCM
> Electrical 1
And there is a damper by the parts number 1VJ-82317-00
> Electrical 1
charliext1vj
- Halfway there
BMurr
- What Bike or Bikes Do You Own?: James autocycle
BMW R100GS
1VK - Previously Owned Bikes: MTX126, Xt600 43F, Kawa GT550,750,GTR1000, BMW R100GS (x2)
Sounds like you have the wrong coil, you have the one that has a bar going through the coil with bolt holes on either end. EBay listing have wrong coils listed in some instances but you can tell by the pictures shown on this thread as to whether you have right coil or not.cadno wrote: Mon Apr 29, 2019 5:30 pm The coil I've bought has a two bolt mount that doesn't seem to match any mounting on the frame.
