Engine guard (protector)
bosley1980
Trusted
Trusted
What Bike or Bikes Do You Own?: YAMAHA XT600E (1998)
YAMAHA TENERE 700 (2019)
HONDA CB1100RS (2020)
Previously Owned Bikes: BMW R1200GS (2006)
HONDA CRF250RALLY (2017)
YAMAHA XT660Z Tenere (2013)
HONDA CRF250L (2015)
MZ150ETZ (1988)
Post by bosley1980 »
Now in progress "Engine guard (protector)"
for XT600E
maybe is compatible with XT600 (must check after finish product)
NOW step one paper model converted into 3D
1) version A
2) version B
Material will be mild steel 3mm or 4mm with powder coating
Re: Engine guard (protector)
Z`s & E`s have different mounting points Radan, but i think there is a market for this on 600E for sure. :nordie:
bosley1980
Trusted
Trusted
MZ150ETZ (1988)
Hi Mezo you have absolutly right, but this problem will solve various attachment as it is on this photo
protection of a sheet of another type solved by a reduction (which will be mounted separately).
It will depend on what motorcycle you order slywink:
Front mounting point for rubber washer, metal bushing and screw
or screw only
Hodgo1981
What Bike or Bikes Do You Own?: Yamaha WR250F 2006
in the future:
xt600 or xt600z
Previously Owned Bikes: 1989 XT600
Post by Hodgo1981 »
Great Idea.
A few things to consider, as mentioned mounting systems will be slightly different.
If you want to make it a True bashguard (as opposed to debris deflector) stronger mounts required - particularly at the rear, 2x 6mm bolts into poorly mounted threads is not really strong enough
Most importantly make sure the oil draining system is easy mess free. The standard one fills with oil when i do an oil change on my 43f.
bosley1980
Trusted
Trusted
MZ150ETZ (1988)
I know
XT600 has different mounting points as XT600E = I count on it
But the rear grip on the M6 is probably sufficient when it is there from the manufacturer. :book:
I personally have rivet nuts smile:
The oil draining system will be added as soon as the fixation and correction is verified.
It's not that easy to have a 3D laser device to focus the entire motorcycle at 1mm!
I have to check the points in the space and then I can do more and more variants and improve them.
(Today I made sample from 1mm thickness, tomorrow check mounting points)
