Motoforms Tank Fitment on a 55W
mhouck
What Bike or Bikes Do You Own?: Ténéré 55W, BMW R1100 GS
Africa Twin XRV 650 (RD03)
Previously Owned Bikes: Kawasaki KLR 650
BMW F650 Funduro
Post by mhouck »
If anyone has a Motoforms (44 litre) tank on a 55W, I'd love to see the fitment and if any modifications are necessary to the frame.
Re: Motoforms Tank Fitment on a 55W
If you scroll down about 3/4 of the way, theres a 34l wearing a big Motoforms tank (I think), not a lot else out there
http://rallye-tenere.net/Umbauten.html
Unless somebody chimes in i think you`re going to have to suss this it out yourself, only advice i can give is to make sure there is adequate foam on the backbone of the frame to support the extra heavy load (approx 36kg) spread the load evenly so as not to crack the tank.
I would suggest fixing the seat in its correct location & then offer up the tank so it matches (no gap) then remove the seat & fabricate a rear fixing & the front fixing, on the original tank they are bolted at the rear & the front is located in to the two rubber bungs which stops it lifting.
Those are your two main challenges (stopping it lifting) especially if you drop the bike on its side, post some pics of the underside of the tank so we can advise.
