Trouble with starting hot engine
Re: Trouble with starting hot engine
steveloomis
- What Bike or Bikes Do You Own?: 81 RD350LC w/84 RZ engine
85 RZ350
84 XT600
86 XT600 - Previously Owned Bikes: Honda 50's, 90's, Yamaha Twin 100, 68 DT1, '73 DT-3, 73 RD350, '77 DT250
Can anyone explain this wacky advance curve? No where does it match the stated advance in the text above it. I programmed my Zeeltronic CDI advance curve to match the upper line. Bike is easy to start in warmer temps 1 or 2 kicks, hot start is not a problem, usually 1 kick. Cold weather is more difficult to start. I have not played with the fuel screw at the front of the primary carb. Maybe a bit more fuel will help the cold weather start...
In my opinion the wide advance curve is saying the advance can be anywhere between the lines... Pretty sloppy... Even the RZ350 with stock analog advance has a single advance curve.
Steve
Steve
Casterton
- What Bike or Bikes Do You Own?: Yamaha 600 xt tenere 34L,
- Previously Owned Bikes: Moto guzzi v50, 65, 700, Honda 250 XL
Had exactly the same issue, the heat was caused by low oil - below minimum
, after the bike was hot, noway charlie would it start until it cooled down. It had a new CDI and spark plug the HT lead looked ok.
The oil level was a bit of trickery in the way you need to have the engine warm to take the measure, the manual gives you the correct procedure. Made the mistake of draining the oil, filling the tank to the maximum level on dipstick and left it as is, all that oil drained out into the engine and left an almost empty oil tank.
Now the bike has the right running temperature (right oil quantity) and sprayed a serious load of WD40 over the solenoid and HT lead to take out any moisture and is kick starting hot cold without the need of a red face!
Vitti
- What Bike or Bikes Do You Own?: Honda Nighthawk
Yep, low oil will do that.Castereton wrote: Thu Mar 16, 2017 9:31 pm Had exactly the same supplements for gaining muscle with the heat low oil - below minimum, after the bike was hot, noway charlie would it start until it cooled down. It had a new CDI and spark plug the HT lead looked ok.
