started my resto on this machine, intending a ground up rebuild, see how it pans outShark's 39E
blackshark
- What Bike or Bikes Do You Own?: 39E Tenere, 36A TT600, 1VJ Tenere, Honda CB900 Boldor, Suzuki T350, M63 Ural
- Previously Owned Bikes: numerous
Shark's 39E
blackshark
blackshark
Re: Shark's 39E
can i enter this wheel into the 'most rotted list', the tube still held air.
[/URL[URL=http://s398.photobucket.com/user/blacks ... 8.jpg.html]
Re: Shark's 39E
Yep that's the worst cancer ive seen.
blackshark
Re: Shark's 39E
The previous owner said the bike sat in the shed for years and his dog would piss on the wheel. that wheel is off my spares bike, I thought being in worse condition than the wheel on the bike I'm restoring, i'd rebuild them first while keeping the others intact till I've finished lacing up.Mezo wrote:Yep that's the worst cancer ive seen.![]()
blackshark
blackshark
Re: Shark's 39E
The middle cam journal seems to be in bad condition, the corresponding part of the cam not so bad or am I mistaken?
is that serviceable or repairable?
I found an engraved number on the barrel, head & head cover, probably from being in a machine shop at some.
I can see a bead of sealant where the engine cases join, so it's been apart at some stage, the con rod doesn't appear to have any slop(apart from a bit of side to side), i still need to have a look down inside to check out the gears, I've ordered one of those usb camera things, yet to arrive.
blackshark
Re: Shark's 39E
I took the head, cover & cam to a motorcycle engineer, he said just give it a bit of wet & dry to remove any high spots and just use it, he said similar things used to happen to old Honda XRs.
Probably lack of oil getting there.
blackshark
Re: Shark's 39E
I have read that you can tidy up the journals by lapping down the cam cover and head joint, effectively closing the bore down and then running a hand lap/hone through to restore the size.
Stands tidy
Stands tidy
