Electrical Fuel pump?
oldmekker
What Bike or Bikes Do You Own?: Yamaha XT600 Tenere
Post by oldmekker »
Hi, all Gurus!
The original fuelpump on my XT600 Tenere isn't any good, if I run out of gas from the main tank, the pump does'nt manage to pick up gas from reservetank just by running startmotor.
I did buy a electrical fuelpump intended for a carburettor engine, but how can I connect it so it stops when engine stalls? For instance in case of a crash and the gnition is left in ON position?
Is it possible to connect via a relay to somewhere on the regulator / rectyfier?
Rgds
Oldmekker.
2001 KTM 300XC
Re: Electrical Fuel pump?
Post by scottieh »
Seems to make sense that you could hook it up to a split of the output of the reg/rect before it gets to the battery. Or would that divert too much energy from the charging system to properly charge the battery?
-edit-
I removed my vacuum fuel pump completely from my 3AJ. Was never happy with its performance.
Just buy another vacum pump, search "fuel pump" top right of screen, lots of info. :thumb:
ausrally
What Bike or Bikes Do You Own?: BMW1200GS
Previously Owned Bikes: 1VJ Tenere
XL500S
XT600E
GPZ1100B1
Post by ausrally »
A lot of injected bikes use a "Tilt or Tip Over switch" to cut power to the pump in the event of the bike falling over (accident)
http://www.ebay.de/itm/LOOK-KAWASAKI-KL ... 19e64bfb6e
This is just a Kawasaki sample, but there are others around.
Matt-Tenere
What Bike or Bikes Do You Own?: Yamaha Tenere 600 3AJ '89, Cagiva Elefant 900ie x2,E900,Beta 300 RR ,Yamaha Tenere 1VJ, Husqvarna CR 250 '76 twinshock
Previously Owned Bikes: Various motocross bikes ranging from 1975-2003,all the Jap brands.Enduro bikes also,Husaberg 450,Husqvarna 360, Italian TM's were a favourite.Road/trail bikes including 3 Yam Tenere 600 over the years,MTX 200,Aprillia RX 125,DRZ 400,DR 350s...
Post by Matt-Tenere »
Fuel injection pumps run at a much higher pressure and are a fair draw on the electrics.I would go with Mezos suggestion and learn to be nifty at changing to reserve whilst on the move before the engine stops.
ausrally
XL500S
XT600E
GPZ1100B1
Post by ausrally »
This wasn't a suggestion to run a fuel injection style pump, just a switch to turn off the pump he already has in event of an accident, as this was his original question.
Use a relay wired to your battery & alternator, or as Mezo said just get another vacuum pump.
Or fill up more :-)
