Brit calling in from Zurich. New to this forum and also new to the XT world.
I bought a 1986 XT600 43F for cheap and reviving it.
I took apart the carburetor and cleaned it so it looks (and feels) brand spanking new (well almost)
I have a problem with the needle and its placement in the primary carburetor throttle valve.
this is how I removed the needle from the valve:
spring - plastic washer - circlip - plastic washer
after putting it back together i noticed the valve not moving well anymore. took it apart again and it turns out the needle was crooked.
checked the need (straight) checked the throttle valve (moving perfectly without the needle)
after examining the throttle valve I noticed this metal plate sitting inside the valve which has a small nipple protruding...
so if there is a washer lying on top of this, the washer wont sit flush, thus the needle will be crooked.
I also noticed that this nipple sits PERFECTLY in the gap of the circlip.
so the diagram in the manual also states that there is a washer on the bottom and not the circlip
I am puzzled!?
