Danjets Honda Transalp
Re: Danjets Honda Transalp
Danjet600 wrote:just stickers........... or has it been tweaked by a suspension guru :scratch:
Dunno but looks cool, shit how clean are they as well.
Shano
Post by Shano »
I thought of your post yesterday when I got my rebuilt forks back from Kiwi Suspension Solutions (KSS) with stickers on them. KSS are recognised experts and the forks are transformed, just fantastic.
But how would anyone know, by looking at the forks, that I had spent a bundle on making them good?
Yours may well have been tweaked by a suspension guru - I guess you have to give them to a guru to see if he recognises any engineering work that's been done.
The fame was like a drug, but what was more like a drug was the drugs.
Danjet600
Post by Danjet600 »
checked out the web site, only seem to cover late model bikes so probably just stickers :cry:
Murray Walker
mazi
What Bike or Bikes Do You Own?: Yamaha XT600Z Tenere 1VJ --sold
Yamaha XT600 43F
Yamaha XT600 Tenere 3AJ
Honda Transadventure PD06
Junak Chopper 500ccm
Post by mazi »
Danjet600 wrote::ola:
some parts arrived today slywink:
XR650 front end
Is this frontend from XR650R or XR650L ?
I bought from XR650L, it fits Plug&Play into XLV frame mounts. Bearings are ideally the same in XR and XLV.
I've mounted new seals, fill new oil and this suspension works great !
So you made good decision bouying this frontend :-)
There is one more thing to do - You should mount bigger brake disc. I Have brake disc (diameter 320mm) and front rim from KTM LC4 which fits ideally for 17mm front axle:
I;m watching your progress
greets, mazi
Polish XT&TT forum:
www.forum.yamahaxt.pl
Danny is going to do the 320mm conversion, this should turn out to be a great little bike when its done. :star:
Danjet600
Post by Danjet600 »
yep something like this
650 hawk disk bolts onto transalp hub, and i don't know about the brembo caliper but that would be nice :drool:
Murray Walker
You would have to do similar to what i did on my DR project, Brembo make caliper extension brackets to do the 320 conversion but whether they make one for your forks?
Danjet600
Post by Danjet600 »
got the swing arm bolt out :flogging:
the correct tools for the job
i heated the rear of the engine case, screwed the nut on until it touched the frame then wound it back out so there was a 2mm gap to the frame
put the socket on the nut and used my modified air chisel on the socket to start pushing the bolt out and just wound the nut back as it got closer to the frame
millimeter by millimeter it started to move, the centre bush was the problem
this bolt in the linkage is also seized not a sign of grease in there :huh:
i'm impressed with the engine enamel it didn't blister or flake off with the heat from the torch
Murray Walker
Danjet600
Post by Danjet600 »
XR650 front end
XR650L front end, mazi post a pic of your bike for us to see :sherlock:
Murray Walker
Danjet600
Post by Danjet600 »
got the motor out tonight, now have to find a powdercoater that can match honda colours
also after much heating and swearing got the bolt out of the swingarm linkage :rage:
Murray Walker
