Been busy. Time for some pretty pictures. Got the engine slapped back together and cleaned up for painting
Had to keep track of all these little guys. Rubber spacers between the fins to reduce vibration I suppose?
And this is what it looks like after it's had its makeup on!
Not too shabby. Joel did the work while I was on holiday in the desert
I'm keeping the inspection caps silver
And then to make this bike like most others rebuilt through this forum, I've decided to shave down the fins! Slick!
There's a lot of work that goes into shaving down these fins. Ran through a few Dremel tips to do it, and it took about two hours, but it's definitely worth it
And just like that it's back in the frame!
Looks nice
And then came the ultimate test. Starting it!
[youtube]UWwKn53Bumo[/youtube]
In short, it passed. It ran, idled okay (without an airbox), and shifted through all the gears properly. We did discover a small oil leak coming up from the right hand side case where the filter bolt goes through the case cover into the crank, which was due to the stripped out thread that's been a bane of my existence for over a year. Well, we finally took care of that today when we got a thread insert that goes into a larger hole you drill out and tap, and then screw it in and lock it in place. They're really nifty and they are much better and more permanent alternatives to helicoil inserts. We drilled out the M6 hole to around 10mm and then tapped it to M10 1.25.
The Keensert screws into the thread and those little tabs get punched down and deform the thread inside the case ensuring they'll not back out. Then the stock M6 1.00 bolt will screw right back into it, no fuss, no muss.
It took all day to figure out that's what we needed but once Joel saw it at the bolt store he said "Oh! That's it!" and we got everything needed. So we put it in and it tightened down like a real case should. We spent the rest of the day detailing the frame and tomorrow we paint. After that it's just a matter of painting the tank and plastics, waiting for a few extra parts for the swingarm, and total reassembly. This thing is really close to being done. Nearly all mechanical work is complete, and now it's all cosmetics.
So close.
