This was going to be interesting as I struggled to find plans or decent idea's for my frames. So first I had a few sets of lugge "hoops" made and then started planning out the type and design of the frames.
I wanted something sturdy - but decent looking....!
Step 1 - had some spare 20mm x 5mm flat bar lying around so started with this as a base mounting point!
once I guaged the angle of a mounting plate, this was welded onto the hoop and held in place with pliers to see whether it would work...
Looks decent enough.....
the other one....
I used 8mm Stainless bolts with mushroom caps and 5mm Allen key to mount - after tapping the thread in the mounting plate that was welded to the hoops
Mounting would be from the footpeg brackets to ensure minimal stress on the frame...
A Spare "hoop" will do nicely as a tail-end bracket for a topbox or to allow the side luggage to be fully interchangable with it as well...
Aaaah - the good old Tooltube! Perfect time to add the mounting brackets!
All the design and welding was completed and the sets sent for Powder coating.....
Arrived back after 2 days...........
SUPER CHUFFED
Of course there are 2 XT's ..... so two sets were made using the first as a template!
AND as "Dad" was the funder of the project... it's only fair that MY bike gets the first set fitted
So now for the design of the luggage & bags to attach to the frames.......... well technically I already have the design... just waiting for the quotes from China!
